Dimming button with status
is it possible to have a button in visualization for 0-100% control (for example light control) but at the same time icon of the button would show status of the same object (if 0 - inactive, if >0 - active)?
If I put VALUE object into 'Main object' and 1bit STATUS object into 'Status object' it partly woks, but when I try to change value it shows NaN
I think the closest you can get is via widget. Create w widget with your 0-100 control and then attach it to your bit status object.
