Panasonic projector IP control
I need help to control Panasonic PT-VZ580 with LM.
There is IP control in this projector and I have all necessary commands from manual (I attached it), but I don't know how to send them from LM.
Maybe someone have similar control example or smth.
Full manual
Make sure that password is disabled on the projector and command port is set to 1024. Change 192.168.1.111 to projector's IP.
For command with a parameter try it either like IIS:HD1 or IISHD1 (documentation is not clear on this point).
function tcpsend(data, ip, port)   local sock = require('socket').tcp()   sock:settimeout(3)   local res, err = sock:connect(ip, port or 1024)      if res then     res, err = sock:send('00' .. data .. '\r')     if res then       res, err = sock:receive('*a')     else       alert('send failed: ' .. tostring(err))       end   else     alert('connect failed: ' .. tostring(err))   end   sock:close()   return res, err end -- send Power ON res, err = tcpsend('PON', '192.168.1.111') log(res, err)
Ok, thank you for help!
We also need to control other projector over IP - Cineversum.
Could you please help with this one too?
Heres some examples from manual, and full manual:
Full manual
Any thoughts?
function tcpsend(data, ip, port)   local sock, res, err   sock = require('socket').tcp()   sock:settimeout(5)   res, err = sock:connect(ip, port or 20554)      if res then     res, err = sock:receive(5)     if res == 'PJ_OK' then       sock:send('PJREQ')       res, err = sock:receive(5)       if res == 'PJACK' then         sock:send(data)         res, err = sock:receive(6)       else         alert('invalid/no ack: ' .. tostring(res))         end     else       alert('invalid/no init: ' .. tostring(res))       end   else     alert('connect failed: ' .. tostring(err))   end   sock:close()   return res, err end cmdon = string.char(0x21, 0x89, 0x01, 0x52, 0x43, 0x37, 0x33, 0x30, 0x35, 0x0A) cmdoff = string.char(0x21, 0x89, 0x01, 0x52, 0x43, 0x37, 0x33, 0x30, 0x36, 0x0A) res, err = tcpsend(cmdon, '192.168.1.111')
