Do you get configuration form when you click the sensor row in 1-wire table? If so, you have to set "Poll interval" to something more than zero, 5-15 seconds or so, map object to sensor value. If it tells you that support for this device is not implemented, please contact our support. Family ID 10 is supported in current beta firmware.
(15.01.2016, 05:40)admin Wrote: Do you get configuration form when you click the sensor row in 1-wire table? If so, you have to set "Poll interval" to something more than zero, 5-15 seconds or so, map object to sensor value. If it tells you that support for this device is not implemented, please contact our support. Family ID 10 is supported in current beta firmware.
Hello
No I get no configuration when I click the Sensor. It is possible to get the beta firmware for testing.
08.08.2016, 09:58 (This post was last modified: 08.08.2016, 10:00 by andeug.)
Hi Edgars,
Can you confirm that the support for both sensors has been added in LM4 RC Version: 20160714? I have installed this software on my LM4 and it works just perfect.
Hi, please, tell me if there will be further support for the 1-Wire? It is possible to support other digital sensors, for example, a pressure sensor BMP 180?
BMP180 uses i2c, not 1wire. For all supported 1wire devices see this list: http://owfs.org/index.php?page=family-code-list
Devices that are not available as profiles in 1wire mapper can still be read from scripts.
