not working script with timer
please help me find error. Task - when light in bathroom is off - i want swith on ventilation for 10 minutes. Found timer script at forum, but something is wrong in my script. Group 0/2/1 is 1 when light is Off and 0/2/1 is 0  when light is On. 6/0/1 and 6/0/2 switch On/Off ventilator. When light is off, ventilator starting but not switching off... May be problem is that 0/2/1 is always =1 till light is Off??
-- group address or name Vanna light on/off
addr = '0/2/1'
-- find required object
obj = grp.find(addr)
-- object exists and current state is "on"
if obj and obj.data then -- I think my problem is here but how to change correctly?
  -- delta is in seconds
  delta = os.time() - obj.updatetime
 grp.write('6/0/1', 1)
 grp.write('6/0/2', 1)
  -- switch off when timer expires
  if delta >= 10 * 60 then
    log(os.time())
  log(delta)
  log(obj.updatetime)
 grp.write('6/0/1', 0)
 grp.write('6/0/2', 0)
If your light status object is inverse you need to add not:
if obj and not obj.data then
I added inverse, but anyway something is not correct - timer not working.When light is off, ventilator starting, but not stopping...I put less time, 1 minute, but the same..
What could be wrong?
Is it a resident or a scheduled script?
sorry it is event-based... It shoudbe resident?
Do it like that.
Resident script with interval as you want. This will decide how fast it will switch on and off from receiving false
addr = '0/2/1' addrVent1 = '6/0/1' addrVent2 = '6/0/2' timer = 600 ----------------------------------------------- obj = grp.find(addr) delta = os.time() - obj.updatetime if obj and not obj.data and delta < timer then  grp.checkwrite(addrVent1, true)  grp.checkwrite(addrVent2, true) elseif obj and not obj.data and delta >= timer then    grp.checkwrite(addrVent1, false)  grp.checkwrite(addrVent2, false) end
Daniel,
BIG THANKS!
All is working as needed!
