Nest Thermostat
Does anyone tried to link LM to Google's Nest thermostat?
If yes, can you post scripting to connect to the (online/cloud) API?
Thanks!
Erwin van der Zwart
First, you need to get auth token, after that it's pretty simple with HTTP requests.
Nest docs:
https://developer.nest.com/documentation...ick-guide/
Here's a short code sample:
1234567891011121314151617181920
function request()   local auth, url, res, stat, hdrs   require('json')   require('ssl.https')   auth = '...'   url = 'https://developer-api.nest.com/devices.json?auth=' .. auth   res, stat, hdrs = ssl.https.request(url)   if stat == 307 then     res = ssl.https.request(hdrs.location)   end   return json.decode(res) end res, data = pcall(request) log(data)
Thanks for the info, i have a fully working connection with the REST API (read and write)
Going to add Firebase now to bypass the API call maximum (:
.lua   Nest thermostat with bidirectional communication.lua (Size: 14.56 KB / Downloads: 76)
