Nest Thermostat
Does anyone tried to link LM to Google's Nest thermostat?
If yes, can you post scripting to connect to the (online/cloud) API?
Thanks!
Erwin van der Zwart
First, you need to get auth token, after that it's pretty simple with HTTP requests.
Nest docs:
https://developer.nest.com/documentation...ick-guide/
Here's a short code sample:
function request()
  local auth, url, res, stat, hdrs
  require('json')
  require('ssl.https')
  auth = '...'
  url = 'https://developer-api.nest.com/devices.json?auth=' .. auth
  res, stat, hdrs = ssl.https.request(url)
  if stat == 307 then
    res = ssl.https.request(hdrs.location)
  return json.decode(res)
res, data = pcall(request)
log(data)
Thanks for the info, i have a fully working connection with the REST APIĀ (read and write)
Going to add Firebase now to bypass the API call maximum (:
.lua   Nest thermostat with bidirectional communication.lua (Size: 14.56 KB / Downloads: 75)
