Tunable White template - Wiser for KNX
Is there any template for tunable white thats based on time and location?
I want the color temperature of the luminaries to follow the outdoor temperature depending on time and season.
Some sort of astronomical function.
Is this possible?
Hi!
Have you found that template ?
You can do simple linear transition between min/max temperature based on current time relative to sunrise/sunset.
-- minimum/maximum color temperature
tmin = 2700
tmax = 5000
-- device coordinates
latitude = 0
longitude = 0
sunrise, sunset = rscalc(latitude, longitude)
date = os.date('*t')
now = date.hour * 60 + date.min
now = math.max(now, sunrise)
now = math.min(now, sunset)
pos = (now - sunrise) / (sunset - sunrise)
color = math.floor(tmin + (tmax - tmin) * (1 - pos))
grp.checkupdate('1/1/1', color)
Made some adjustments. Now it gets true midday and goes from sunset to midday (min-max) and midday to sunset (max-min), because temperature function should be a parabola.
tmin = 2700
tmax = 5800
latitude = 0
longitude = 0
midday = (sunset + sunrise) / 2
if (now < midday) then
    pos = (now - sunrise) / (midday - sunrise)
    color = math.floor(tmin + (tmax - tmin) * (pos))
    pos = (now - midday) / (sunset - midday)
