Sony Simple IP Protocol
Hello, we are trying to communicate a Sony TV via TCP and we have a document made by sony that explains the protocol we should use. My question is how we can do to make this control via lua scripts, thank you very much.
.pdf   Steuerungsprotokoll_1.pdf (Size: 239.61 KB / Downloads: 126)
TCP function reference:
http://w3.impa.br/~diego/software/luasocket/tcp.html
Basic example:
123456789101112131415161718192021222324252627
require('socket') -- bravia IP ip = '192.168.1.23' -- IR power off command, must be 24 chars long cmd = '*SCIRCC0000000000000000\n' -- power-on -- cmd = '*SCPOWR0000000000000001\n' sock = socket.tcp() sock:settimeout(3) res, err = sock:connect(ip, 20060) if res then   res, err = sock:send(cmd)   if res then     alert('send OK')   else     alert('send failed: ' .. tostring(err))   end else   alert('connect failed: ' .. tostring(err)) end sock:close()
Thank you very much. It works fine. Now I try to read TV status via Resident Script but doesn't work, I tryied to use the Denon TCP status Scrip from examples but doesn't work.
In Alert page appears Connection Ok and Connection Timeout alternately.
You have to send enquiry command, then you can parse the response to get status info.
12345678910111213141516171819202122232425262728293031
require('socket') -- bravia IP ip = '192.168.1.23' -- power-status cmd = '*SEPOWR################\n' sock = socket.tcp() sock:settimeout(3) res, err = sock:connect(ip, 20060) if res then   res, err = sock:send(cmd)   if res then     res, err = sock:receive()     if res then       alert('receive OK: ' .. tostring(res))     else       alert('receive failed: ' .. tostring(err))     end   else     alert('send failed: ' .. tostring(err))   end else   alert('connect failed: ' .. tostring(err)) end sock:close()
(25.02.2016, 09:37)admin Wrote: You have to send enquiry command, then you can parse the response to get status info.
Hi, I'm trying this but doesn't work. Appears a error like that:
"attempt to call method 'revieve' ( anil value)"
I have two more questions,
first. It's possible to extract volume value from TCP response of TV and convert this value to a KNX 1 byte value?
and the second question, if the tv awnser automactilly the status when you send 'power on', for example, it's possible to read this value without force the status query, and can I read the responses separately by \n?
Its not work with firewall 4/2017 of sony tv bravia. Can you help me?
It works but only when TV is on(not in standby mode). After switching off TV script receive nothing only timeout or connection refused. In documentation there is such info:
"TCP connections are kept among requests but they are disconnected by server if no command is sent from client in 30 seconds."
So I tried sending every 20 seconds ask for power status. But it is not enough.
How can I keep the connection? And also could someone prepare a sample for establishing TCP connection which can receive some info from TV only on event?
Please help me !
I use the code above to turn the TV on and off but it does not work?
My television is sony bravia 79' X900B.
Does anyone know how to turn it off via HTTP?
require('socket')
ip = '192.168.1.16'
-- power-on =1, off=0
on = '*SCPOWR0000000000000001\n'
off= '*SCPOWR0000000000000000\n' --SCIRCC0000000000000001
sock=socket.tcp()
sockConfusedettimeout(1)
a=sock:connect(ip,20060)
if giatri==1 then
b=sockConfusedend(on)
alert('send OK')
b=sockConfusedend(off)
alert('send OK')
sock:close()
function check_tv()
require('socket')
sock=socket.tcp()
sockConfusedettimeout(2)
ip = '192.168.1.16'
a=sock:connect(ip,52323)
if a==1 then
b=sockConfusedend(cmd)
if b==24 then
c=sock:receive()
if c=="*SAPOWR0000000000000001" then
alert("tivi đã bật")
return 1
alert("tivi đã tắt")
return 0
alert("Send failed: ")
alert("connect failed")
sock:close()
Am I wrong?
Sad....
Above doesn't work for me, so i used this:
-- tv standby require('user.sony') sendCmd('192.168.x.xxx', cmd_OFF) -- define your ip
and the library
12345678910111213141516171819202122232425262728293031323334353637383940414243444546
--http://www.openremote.org/display/forums/Sony+TV+HTTP+control --https://www.domoticz.com/forum/viewtopic.php?t=8301 --https://medium.com/@philw_/talking-to-your-sony-bravia-tv-over-http-with-google-now-tasker-xbmc-and-roku-7b71fe634966#.xwswvjd0p -- wol(mac, ip, '60', port) --mac = '00:a0:96:7c:76:dd' require('socket') port = 80 --command cmd_HDMI1 = 'AAAAAgAAABoAAABaAw==' cmd_CH6 = 'AAAAAQAAAAEAAAAFAw==' cmd_MUTE = 'AAAAAQAAAAEAAAAUAw==' cmd_OFF = 'AAAAAQAAAAEAAAAvAw==' function sendCmd(ip, ircmd)  soap = '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1"><IRCCCode>'..ircmd..'</IRCCCode></u:X_SendIRCC></s:Body></s:Envelope>'  -- http request    reqs = 'POST /IRCC HTTP/1.1\r\n' ..         'CONNECTION: close\r\n' ..         'HOST: ' .. ip .. ':' .. port .. '\r\n' ..         'CONTENT-LENGTH: ' .. soap:len() .. '\r\n' ..         'CONTENT-TYPE: text/xml; charset="utf-8"\r\n' ..          '\r\n' .. soap  sock = socket.tcp()  sock:settimeout(3)  res, err = sock:connect(ip, port)  if res then    res, err = sock:send(reqs)    if res then      --log('send OK')    else      --log('send failed: ' .. tostring(err))    end  else    --log('connect failed: ' .. tostring(err))  end  sock:close() end
This Code had an error regarding my Bravia, to turn off.
do not work at all, i had to replace IRCC with POWR
cmd = '*SCPOWR0000000000000000\n'
That did make it work!
