17.09.2018, 20:05
Good, the present is to ask you if there is any way to know if a logic machine is working or energized, this is because in the work where they are installed, I have several logic machines (5 in total) and all have logics so that the system can work properly and the idea is that a logic machine asks another how it is, if the KNX bus is on and if the logic machine is not running or turned on or if there is no response the logic machine, to be able to determine that a problem exists in that board where the logic machine is and that a person can go to solve it (Change the logic machine, reset it or verify if it has electrical input).
Thank you and I will be attentive to your comments.
