I don't know any SE AN but Function Block Editor is application which is by default installed on homelynk. You may want to update your firmware as you have an old one I see. There is no need to install any AN for FB, all is inside. Just go to homepage and look for icons with some squares on it.
(04.10.2018, 11:20)Daniel. Wrote: I just checked what is AN 24 and it is about old puzzle programming which was phased out long time ago. Now FB Editor should be used instead.
Hi Daniel,
thanks a lot for your help. I am trying to have in trend logs the maximum and the minimum day of a solar boiler in the total day, and also to have the operating hours of one more boiler, but it is not working.
Hi Daniel,
Minimum and maximum can be done directly in trend settings, you don't need any logic for that. The operating hours I'm quite sure it should be a timer not event script.
Of course, I have created already 2 trends. The question is how to separate min a max temperature from only one physical sensor (PT100), which measures all time values.
08.10.2018, 22:37 (This post was last modified: 08.10.2018, 22:37 by Erwin van der Zwart.)
Daniel you should know this (:
homeLYnk is now branded as Wiser for KNX, and when you actually have a Wiser for KNX HW then there is a difference as the Wiser for KNX is based on a different HW platform and is approx 3 times more powerfull than a homeLYnk.
If you upgrade a homeLYnk with latest FW then you have the new name in the firmware but not the benefits that the faster new HW brings.
