Threads: 18
(13.11.2017, 17:35)Daniel. Wrote: (13.11.2017, 17:29)Thomas Wrote: Hi
I see 5 languages only. Android 7
https://www.dropbox.com/s/vdgsij5z32fmmj...2.png?dl=0
Hm... I have all of them, see attachment.
OK I found what is it, new app will be in the morning.
Thank you for the quick response!
Threads: 18
New version is on Play store
What's new in this release?
Added new languages to voice control
Auto discovery is switched off when device is on mobile network.
Threads: 101
Thank you both work.
I've a question about translation of commands. In column "names (part of words)" in "Logic Machine Voice App" I can set a list of words. But I can't do it in column "command (part of words)". Or Can I? What's the separator?
Threads: 18
(14.11.2017, 17:48)Thomas Wrote: Thank you both work.
I'm not sure if fully understand you. Command is the only place where you can put more then one word and this is why you can add only one command for this action. Would you like to add more then one command for one action? I can't figure out an example but maybe in your language they are...
Threads: 7
(14.11.2017, 18:06)Daniel. Wrote: (14.11.2017, 17:48)Thomas Wrote: Thank you both work.
actualy, in Russia we want it too.
example:
Your comand is set light in the kitchen to 0%
but this phrase does not have a unique translation
here is russian examples
Set Light in the Kitchen to 0%
Установи яркость на кухне на 0%
Сделай яркость на кухне на 0%
Задай яркость на кухне на 0%
for "Light" we can set different words (яркость, свет, светильник, освещение) in one comand.
but we need to do the same for word "Set"
Threads: 18
(15.11.2017, 10:25)AEK Wrote: (14.11.2017, 18:06)Daniel. Wrote: (14.11.2017, 17:48)Thomas Wrote: Thank you both work.
example:
OK comment taken, I will add it to the list of improvements. for now you have to use several lines for the same.
PS for свет, светильник only свет is needed as both contain the same letters.
Threads: 7
(15.11.2017, 10:33)Daniel. Wrote: OK comment taken, I will add it to the list of improvements. for now you have to use several lines for the same.
You are right, i want to test "све" letters for "свет" and "освещение" for one comand, if it will work, i will let you know.
right now i use "свет" and "свещ" together
Threads: 101
I'm getting white screen with "Access Denied" message on the left upper corner only when I'm trying to use "Home" (local) resource.
The device runs Android 4.2.2.
Doesn't matter what account I use. Everytime I get this message.
In Opera Mini installed at the same device my visu works well.
Browser called "Browser" is completely out of luck because WebRTC support is missing.
Chrome is OK
Threads: 29
Since app uses Android WebView, you need at least 4.4 for it to work.
Threads: 101
(14.12.2017, 18:27)admin Wrote: Since app uses Android WebView, you need at least 4.4 for it to work.
Then the app should be marked as not suitable for 4.2 in google play and shouldn't be offered for 4.2 devices.
Threads: 101
I've an idea for improvement of your Android client. How about client side scripting triggered by like geolocation?
I mean when I approach my office with my mobile phone in my pocket LM turns lights on? I leave and LM turns lights off etc. It can be more sophisticated but I'm trying to describe the principle.
Threads: 4
You can do this already with usage of IFTTT and remote services, Why recreate something that’s already possible?
Threads: 13
Hi Edwin
Great for pointing out this solution :-)
However geofencing starts to get commodity in a lot of solutions, so why not integrate it in the app. In my opinion one should keep the chain as short as possible to have a reliable and responsive solution
Threads: 4
The chain is just as long in both methodes..
App (phone) -> Cloud -> Endpoint
Threads: 18
(03.01.2018, 21:56)npinguin Wrote: Hi Edwin
Thanks for tip. I see only one issue here. European Union recently created very strict rules for data privacy. Due to this we try do not collect any personal data from customers. Location is very personal...
We have plan to comply to those EU rules but this takes time as there is a lot of legal stuff to sort out.
Due to this I would leave it for later. If we brake EU rules then big fines will be given, so big that we can close the business
Threads: 13
I would use a banner and ask explicit concent of the user, you could even integrate it in mosaic and not go through your cloud
https://developers.google.com/web/fundam...-location/
Br
Nicky
Threads: 101
(04.01.2018, 09:02)Daniel. Wrote: (03.01.2018, 21:56)npinguin Wrote: Hi Edwin
Exactly! That's why I'm not interested in any kind of cloud based solution in general. Which means I need to process geolocation directly on the client's device. The client's device must not send its geolocation directly to me (or in worst case indirectly via cloud owned and maintained by someone else) but direct requests for lights, heaters etc.
Threads: 1
09.02.2018, 06:00
(This post was last modified: 09.02.2018, 06:00 by forsterm.)
would it bee possible, to create the ability, that I can take the Android App (and iOS App) in the foreground by lua script for example?
By the way, can I send push notifications from spacelynk / homelynk? Where do I find the needed lua library?
Best regards
forsterm
Threads: 18
(09.02.2018, 06:00)forsterm Wrote: Hello,
I think the only way is via sending push notification and then when user click on it app will open.
For HL/SL you need cloud app but it is not supported by SE at the moment.
Threads: 4
09.02.2018, 11:26
(This post was last modified: 09.02.2018, 11:26 by Erwin van der Zwart.)
You can send Push notifications with HL/SL using this:
http://openrb.com/send-instant-messages-...s-with-lm/
