Threads: 30
(12.03.2019, 10:54)buuuudzik Wrote: I've reinstalled the app, added only 1 LM with static IP and set autoload "Main page" and autostart but unfortunately nothing happen when I start app.
I have Samsung S8 SM-G950F, on of the newest Android version.
OK will upgrade to Android Pie and check, didn't want to do it as heard that battery is drained faster on S9. It will be your fault
Threads: 161
Maybe this is true, because the battery is not so bad as on smartphone but could be better
Done is better than perfect
Threads: 30
Android 9.0 Galaxy S9 so shouldn't be any different from yours. All works fine see video.
https://we.tl/b-w1z3Xi74d8
Threads: 161
I see, it should really nice, but is it working also from outside LAN? Please test that situation because I don't have in my LAN LM and I am using static IP and on my device it still not working(autoopening, normal opening working fine).
Threads: 30
No this works only on Local network
When you out it ask you what you want to do.
Threads: 161
But when user has only 1 LM and it is default it should open it
Threads: 30
In the future we may add default view when not on local.
Threads: 30
Not possible at the moment
Threads: 67
Is there any way to get the app APK file to install it on an Android touch pannel that doesn't have play store?
Threads: 30
Threads: 30
What android is it?
Threads: 30
Can you send your backup to PM to check?
