Android app for LM
#61
(12.03.2019, 10:54)buuuudzik Wrote: I've reinstalled the app, added only 1 LM with static IP and set autoload "Main page" and autostart but unfortunately nothing happen when I start app.
I have Samsung S8 SM-G950F, on of the newest Android version.
OK will upgrade to Android Pie and check, didn't want to do it as heard that battery is drained faster on S9.  It will be your fault Wink
Maybe this is true, because the battery is not so bad as on smartphone but could be betterWink
Done is better than perfect
Android 9.0 Galaxy S9 so shouldn't be any different from yours. All works fine see video.
https://we.tl/b-w1z3Xi74d8
I see, it should really nice, but is it working also from outside LAN? Please test that situation because I don't have in my LAN LM and I am using static IP and on my device it still not working(autoopening, normal opening working fine).
No this works only on Local network Smile When you out it ask you what you want to do.
But when user has only 1 LM and it is default it should open itWink
In the future we may add default view when not on local.
How can i autoload Logic Machine Cloud when i first open Logic Machine app?
So when i just press the Logic Machine App i will redirect immediately to my Mosaic app through cloud.
Is it possible?
Huh Huh
Not possible at the moment
Is there any way to get the app APK file to install it on an Android touch pannel that doesn't have play store?
Here you go
https://we.tl/t-2jC6ogC4tp
(15.01.2022, 13:23)Daniel Wrote: Here you go
Ok, thanks!
I've installed the app and it's working, but I've some issues:
  1. Autoload doesn't work
  2. Using app iframes are not shown using relative links as /scada-vis/schedulers?id=1 doesn't work, changing to include IP/host it works
  3. Svgz images on images/background are not shown on the visulitzation (changing them to png are shown)
Openning the visualitzation, on the same device, using Chrome points 2 and 3 works fine without changing nothing.
Have you any idea about what can be happening?
The device used is an iiyama android panel pc.
Thanks!
What android is it?
(17.01.2022, 08:19)Daniel Wrote: What android is it?
Android version 8.1.0
Can you send your backup to PM to check?
(17.01.2022, 08:30)Daniel Wrote: Can you send your backup to PM to check?
Done!
