Threads: 103
What is my LM trying to say by this red ERROR flag?
https://www.dropbox.com/s/dls8nzzq3zozuf...6.png?dl=0
I can't find any suitable explanation. I've two LMs at the same KNX TP line. First is OK but the second one is flashing between "OK" and "ERROR" message. System log is empty. KNS statistic says nothing. No alarms. No Errors nor log.
Both LMs work.
What can be the problem?
Thank you
Do you have KNX IP features enabled on both devices? What is CPU/IO load on LMs?
Threads: 103
23.11.2017, 09:57
(This post was last modified: 23.11.2017, 10:00 by Thomas.)
- KNX IP is switched on on the "broken" LM only. I've made a printscreen of both settings:
https://www.dropbox.com/s/7f3q9qmwjg5fjk...6.png?dl=0
Loads:
Working LM: Load averages
0.28 0.17 0.18
Broken LM:
Load averages
0.03 0.14 0.19
Unfortunately I can't find anything wrong. Just the message.
Do have KNX connected/disconnected messages in Alerts tab?
Threads: 103
No. There's nothing suspicious in logs.
Here you can see my alerts log. One disconnect per three days aprox:
https://www.dropbox.com/s/x5hjrvifsoyq8q...0.png?dl=0
Threads: 103
Actually my broken LM just died and is on the way to my office.
So I think the problem was some seriuos HW issue in this LM. First I will try to change the SD card inside.
