MQTT & MQTTS
Smile
Hello everyone,
I am using MQTT packages that embedded systems propose. It is working great and I have a few questions about MQTT in general.
Is the mqtt instance running on Logic Machines able to execute secured mqtt (mqtts) ?
If yes, how and where do we have to store the cafile, certfile, keyfile, crlfile?
Does the mqtt instance running on Logic Machines have broker capabilities, i.e. is it possible to:
Publish topics locally and then subscribe to these topics from another mqtt-enabled computer?
Subscribe to topics locally and then publish to these topics from another mqtt-enabled computer?
Thx to all of you for your help
Security is already enabled, it can be enabled via tls_set:
-- ca.pem is uploaded via `ftp` account to ftp root directory
client:tls_set('/data/ftp/ca.pem')
If you also need client certificate/private key:
client:tls_set('/data/ftp/ca.pem', nil, '/data/ftp/client.crt', '/data/ftp/client.key')
Running broker is theoretically possible, but currnet packages only allow client mode.
