KNX Remote connection
Hello, does anyone have any experience with remote connection to the KNX Bus through LM?
I have tried opening port 3671 in my router but I'm not able to access it.
Make sure that you open UDP port not TCP. Also, LM must have gateway configured in network/interfaces,
Also make sure to check the "use NAT" option in the ETS connection settings
I have done all that, check my settings in the picture attachments to see if there's anything I have overlooked...
The external port 599 is directed to the internal port 3671 for my LM's IP address 192.168.1.150
(21.12.2017, 08:51)Krstfr2k Wrote: I have done all that, check my settings in the picture attachments to see if there's anything I have overlooked...
I think your lm's ip address is not the same as you wrote above, 192.168.10.150 ~= 192.168.1.150
