Threads: 39
12.01.2018, 15:39
(This post was last modified: 12.01.2018, 15:40 by domotiqa.)
hello,
1/ do you know if we can use dmx in the homelynk/spacelynk ?
2/if not I can add this library i guess
https://gist.github.com/jsopenrb/f97f85f...c6766aae6a
3/ is there a way to use th lm as slave in dmx.
for example, the dmx turn on light on knx side ?
thanks
SE ECO EXPERT
Threads: 28
You can use it as master like this example
https://forum.logicmachine.net/showthread.php?tid=16
SE has Application note for this I think.
No slave option.
Threads: 39
cool, thank a lot.
And can we have multiple master on dmx ? for example, spacelynk and professionel controler for show...
SE ECO EXPERT
Threads: 7
No, there can be only one master in a line, you need something like a DMX merger.
Threads: 39
27.04.2018, 05:38
(This post was last modified: 27.04.2018, 06:19 by domotiqa.)
(12.01.2018, 20:33)Erwin van der Zwart Wrote: No, there can be only one master in a line, you need something like a DMX merger.
ok thank you
And just another question, did someone use DMX/IP gateway using art-net protocol ?
SE ECO EXPERT
