DMX lighting control
This is again a work in progress that might be used as inspiration. I have this as a user script that I include in KNX objects to turn DMX lights on/off or to a specific value. All DMX in my home are eldoleds. The user script I use is called user.mydmx
What I am working on is the dimming part... not really sure why it is not working.
-- set of variables for zones in the apartment
-- these are the DMX channels to be set
alllights = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20}
bathroomlights = {7,8}
bathroomheadlight = {7}
bathroomfloor = {20}
livinglights = {5,6,9,10,11,12,14,15,16,17,18,19}
kitchenlights = {13}
bedroomlights = {1,2,3}
entrancelights = {4}
-- turns DMX stripe to full on or off based on two groups
function dmxtoggle(channel, state)
  -- group that contains the value for ON. I use a slider to define the intensity of on/off
  on = grp.getvalue('5/7/17')
  -- group that contains the value for OFF
  off = grp.getvalue('5/7/18')
  if (state == true) then
    DMX.set(channel, on)
    return on
    DMX.set(channel, off)
    return off
-- loops through all lights
-- lights is an array of the channel(s) to be set
-- state is the state of the group
-- stategroup is the group that holds the state of this light
-- slider is the group of a slider for setting the light level
function dmxlooptoggle(lights, state, stategroup, slider)
  for index, value in ipairs(lights) do
    sliderstate = dmxtoggle(value, state)
  -- write state to state group (that way pushbuttons know the state)
  grp.write(stategroup, state)
  -- if a slider object was provided, then update the internal value
  -- this helps keep the visualization consistent
  grp.update(slider, sliderstate)
function dmxloopset(lights, value)
  for index, channel in ipairs(lights) do
    DMX.set(channel, value)
-- dimm light up
function dmxdimmup(lights, intencity)
    intencity = intencity + 1
    DMX.set(value, intencity)
-- dimm light down
    intencity = intencity - 1
-- make it easy to show if a light is on off when also using sliders
function onoffvisu(onoffgroup, state)
  if (state > 0) then
    -- set on/off to on
    grp.write(onoffgroup, true)
    -- set on/off to off
    grp.write(onoffgroup, false)
An example of usage:
require('user.mydmx')
dmxlooptoggle(livinglights, event.getvalue(),'5/7/21','5/1/21')
This turns the lights in the living room on or off depending on the value of the KNX object.
Hi, very nice work and thanks for sharing. Did you ever get the dimming part to work?
(Bump)
