dmx and hl&sl
hello,
1/ do you know if we can use dmx in the homelynk/spacelynk ?
2/if not I can add this library i guess
https://gist.github.com/jsopenrb/f97f85f...c6766aae6a
3/ is there a way to use th lm as slave in dmx.
for example, the dmx turn on light on knx side ?
thanks
You can use it as master like this example https://forum.logicmachine.net/showthread.php?tid=16
SE has Application note for this I think.
No slave option.
Yes you can..
.pdf   AN033_DMX control with spaceLYnk.pdf (Size: 681.53 KB / Downloads: 49)
.gz   AN033_DMX_scripts.tar.gz (Size: 5.85 KB / Downloads: 17)
cool, thank a lot.
And can we have multiple master on dmx ? for example, spacelynk and professionel controler for show...
No, there can be only one master in a line, you need something like a DMX merger.
(12.01.2018, 20:33)Erwin van der Zwart Wrote: No, there can be only one master in a line, you need something like a DMX merger.
ok thank you
And just another question, did someone use DMX/IP gateway using art-net protocol ?
