Custom events in JS
I want to create some custom events in JS. I've found such solution:
var event = new CustomEvent(     "newMessage",     {         detail: {             message: "Hello World!",             time: new Date(),         },         bubbles: true,         cancelable: true     } ); document.getElementById("msgbox").dispatchEvent(event);
https://www.sitepoint.com/javascript-custom-events/
But to do this I must connect event to some nearly dummy selector but I know that currently there are such events:
.. grp.listen('6/0/54', function(obj, type) { ...
which not need any HTML selector. How to do something similar, e.g. generate event when plan changed for whole scripts?
grp.listen has its own store for listeners. If you want to create something custom you will have to create your own implementation. So it might be easier to attach custom events to $(window). As for plan change, there's already a 'showplan' event attached to document.body:
$(document.body).on('showplan', function(event, id) {   console.log('new plan id is', id); });
Very nice and I didn't know about this. Very nice and very thanks Smile
Can you eventually prepare some example how to do the smallest one custom event like grp.listen?
You can also attach custom events to a plain object via jQuery:
var myobj = $({}); myobj.on('myevent', function(event, p1, p2) {   console.log(event, p1, p2); }); myobj.trigger('myevent', [ 'param1', 'param2' ]);
SuperbWink
