Convert from Wh to Kwh
Hi there,
what's wrong with this below?
Consumo_impianto = grp.getvalue('3/3/30')
os.sleep(0.5)
Consumo_ftv_fase_1 = grp.getvalue('3/3/24')
os.sleep(0.5)
Consumo_ftv_fase_2 = grp.getvalue('3/3/25')
os.sleep(0.5)
Consumo_ftv_fase_1 = grp.getvalue('3/3/26')
os.sleep(0.5)
Consumo_pdc = grp.getvalue('3/3/27')
os.sleep(0.5)
Consumo_impianto_kwh = (Consumo_impianto / 1000)
os.sleep(0.5)
Consumo_ftv_fase_1_kwh = (Consumo_ftv_fase_1 / 1000)
os.sleep(0.5)
Consumo_ftv_fase_2_kwh = (Consumo_ftv_fase_2 / 1000)
os.sleep(0.5)
Consumo_ftv_fase_3_kwh = (Consumo_ftv_fase_3 / 1000)
os.sleep(0.5)
Consumo_pdc_kwh = (Consumo_pdc / 1000)
os.sleep(0.5)
grp.write ('3/3/121', Consumo_impianto_kwh)
os.sleep(0.5)
grp.write ('3/3/124', Consumo_ftv_fase_1_kwh)
os.sleep(0.5)
grp.write ('3/3/125', Consumo_ftv_fase_2_kwh)
os.sleep(0.5)
grp.write ('3/3/126', Consumo_ftv_fase_3_kwh)
os.sleep(0.5)
grp.write ('3/3/127', Consumo_pdc_kwh)
Nothing write.
Are you using modbus templates? If yes you can add a scale factor in the template.
Hi Erwing,
no. Data comes from KNX (4 byte integer). Active Energy.
I remember that with an old version of Logic Machine there was not any problem. I cannot explain it.
Have you logged the outcome?
Maybe you need to round it with math.round(value, 0)
You can also remove the delay’s on all items that are not grp.write related.
OK Done. Thank you!!
