knx/tp error
#21
The same way that you cannot usually have more than 32 devices on a single RS485 bus. The more devices you have the harder it is for the transceiver to drive the line in order to transmit the data. This is usually solved by divining the line into two segments connected by a line coupler.
Having more than one KNX power supply is a standard solution for longer lines.
Thank you,
also as I see partly answer on my question on other thread about KNX limits..
Big thanks!
(27.10.2020, 12:14)admin Wrote: This can happen if the line is overloaded with too many devices, how many do you have there?
56 devices
