homelynk img
Hello
am having an issue with my homelynk : it contains an old version of a project i did , and it doesn't save any modification i do once i cut off the power .
i did a factory reset , and a firmware update , always back to the same old version
Anything to do ?? thank youu
You need to replace SD card because it probably became read-only.
(14.03.2018, 09:23)admin Wrote: You need to replace SD card because it probably became read-only.
should i just replace it ?  there is any soft or installation to do ??
yes  here
if it is old one then use this recovery firmware
yes  here
does the recovery is the same for homelynk ??
yes it is the same
(14.03.2018, 17:40)Daniel. Wrote: yes it is the same
well thank you for your support
i had to change the SD card , apparently it's dead
