Threads: 6
21.03.2018, 10:49
(This post was last modified: 21.03.2018, 10:51 by Kapetanidis Panagiotis.)
hello,
If i had more than one object in the same group address, how to can insert all objects?
it does not allow me to insert two or more times the same group address.
Thank you
Threads: 8
21.03.2018, 10:58
(This post was last modified: 21.03.2018, 10:58 by Erwin van der Zwart.)
A group address is only needed once, if you have multiple objects that needs to listen to a command you need to configure it like that in the ETS.
This is how KNX works and cannot be done another way..
Threads: 103
Maybe related question. Is there a NATting KNX device? Does it exist? Imagine situation you have two KNX network. You can't change group addressing but you want to controll them from one point. Do you know a line coupler able to translate main group address (in 3 numbers addressing scheme) up to 16?
I don't need it. I just got curious when I read the question.
