23.03.2018, 10:47
is there an app or something to configure and monitoring dali ballasts and devices?
Tnx
Peppe
Tnx
Peppe
DALI MANAGEMENT
23.03.2018, 10:47
is there an app or something to configure and monitoring dali ballasts and devices? Tnx Peppe
23.03.2018, 12:36
For configuration the external tools are best like this http://www.tridonic.com/com/en/software-...urator.asp You can monitor by scripts. All the commands are here http://openrb.com/docs/dali.htm There is an app on its way but it is in beta state right now. BR
26.03.2018, 10:42
(23.03.2018, 12:36)Daniel. Wrote: Hi
29.04.2019, 11:17
(This post was last modified: 29.04.2019, 11:18 by fabiorusco.)
I was in a underground tunnel without possibility to connect to internet. I needed install DALI app in a Spacelynk, but browser wrote "DNS error". Can I install from file the dali app? Where i can find it? When i backup a visualisation with app the app are not backupped. What I must do for have the comoplete backup? Best regards.
29.04.2019, 11:41
It is SE app and they do not want to share it as a file. You need to ask SE but I heard you already did. BR
29.04.2019, 11:56
If I create visualisation on a homelink connetcted to internet and insert the app fon each dali gateway,the only mode to transfer the full visualizzation on Spacelynk is manipolate the sd card internal of spacelynk/homelynk? Best regards FR
29.04.2019, 12:53
(This post was last modified: 29.04.2019, 12:54 by fabiorusco.)
extract it and duplicate?
Also if i prepare on homelynk and transfer on spacelink? FR
29.04.2019, 13:11
No this will not work. Image from SL will not work on HL and other way around. Project backup can be transferred.
29.04.2019, 13:51
but so I can't transfer the app.
FR |
« Next Oldest | Next Newest »
