DALI MANAGEMENT
is there an app or something to configure and monitoring dali ballasts and devices?
Tnx
Peppe
For configuration the external tools are best like this
http://www.tridonic.com/com/en/software-...urator.asp
You can monitor by scripts. All the commands are here http://openrb.com/docs/dali.htm
There is an app on its way but it is in beta state right now.
(23.03.2018, 12:36)Daniel. Wrote: Hi
I was in a underground tunnel without possibility to connect to internet. I needed install DALI app in a Spacelynk, but browser wrote "DNS error".
Can I install from file the dali app? Where i can find it?
When i backup a visualisation with app the app are not backupped. What I must do for have the comoplete backup?
Best regards.
It is SE app and they do not want to share it as a file. You need to ask SE but I heard you already did.
If I create visualisation on a homelink connetcted to internet and insert the app fon each dali gateway,the only mode to transfer the full visualizzation on Spacelynk is manipolate the sd card internal of spacelynk/homelynk?
Best regards
FR
Card image would do the trick.
extract it and duplicate?
Also if i prepare on homelynk and transfer on spacelink?
FR
No this will not work. Image from SL will not work on HL and other way around.  Project backup can be transferred.
but so I can't transfer the app.
FR
