Disable all script at once
Is there any possibility to disable all scripts at once ?
You can set the same category for all scripts and use script.categorydisable function:
http://openrb.com/docs/lua.htm#script.categorydisable
It does not work for me. But I found a solution.
1-) I exported all the scripts.
2-) I open vi winrar related .tar.gz file.
3-) I open scripts.json file via notepad
4-) I change active":1 with active":0 finf and replace then save the file
5-) I import related script backup one more time
