23.05.2018, 13:40
Hello everybody!
I was wondering if it is possible to make this kind of "effect" with a simple RGB strip. When holding a simple push button set to dimming, colors of the strip would go across the spectrum of all colors (with speed / step size as I choose), when released it would stay at that color. Second button would do the same but backwards. Not sure if this would be any effective but it's the only way I thought of to make this using a physical push button. I have 3 unsigned integer group adresses (R,G,B). I tried to do it with this script I lightly modified but it doesn't work well. The script is in two event scripts, both 3 byte dimming from a pushbutton, one is set to brighter (ON) and the second one to darker (OFF).
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051
step = 1
stepTime = 0.001
ballastAddress1 = 19 --RED
ballastAddress2 = 27 --GREEN
ballastAddress3 = 28 --BLUE
gatewayID='internal'
valuein = event.getvalue()
require('user.dali')
res, err = dalicmd(gatewayID, 'queryactual', { addrtype = 'short', address = ballastAddress1 })
res, err = dalicmd(gatewayID, 'queryactual', { addrtype = 'short', address = ballastAddress2 })
res, err = dalicmd(gatewayID, 'queryactual', { addrtype = 'short', address = ballastAddress3 })
-- read ok
if res then
status = res:byte()
while( valuein==9 ) do
status = status + step
if (status >254) then
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress1, value = 254})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress2, value = 254})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress3, value = 254})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress1, value = status})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress2, value = status})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress3, value = status})
valuein = grp.getvalue(event.dst)
os.sleep(stepTime)
while( valuein==1 ) do
status = status - step
if (status <0) then
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress1, value = 0})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress2, value = 0})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress3, value = 0})
os.sleep(stepTime)
