Threads: 87
I have a big room with 3 thermostats. Could there the some logic to compare in the logic module to compare the three temperatures to get an average temp. Then use this to control the room?
Threads: 10
Is rounding needed? I normally just sent the value to the knx driver and let it deal with the formatting. (Though thinking about it I have not checked if its rounding or just chopping off the decimal places...)
Threads: 87
Scripts is hard learning for me. So i try but really not my best side.
Ok so i put a new script in event based. Then i pushed the run script button on the bottom.
But then it flooded my knx group monitor writing the value every milli second.
What did i do wrong?
Threads: 7
You probably have the event on the output, this will retrigger the event every time the output is written.
For the correct avarage like sample above you need to put a tag on the 3 input values and set the event script to the same tag. Make sure the output is NOT tagged like the inputs.
Threads: 7
If script is to hard for you at the moment you can always use the FBeditor app, there should be a average graphic block.
Basic functions are fine to do with it..
