different value throughout the day
Is it possible to send diffrent values from a 1bit signal compared to the time of day?
Yes that is possible, but can you describe your task in more detail?
(10.06.2018, 20:13)Erwin van der Zwart Wrote: Hi,
Event based script that sends a value between for example 08-13 another value between 13-14 and so on.
Also needs a script that does the same automatically, but that I can start/stop via a bit value or a scene value.
Try this:
now = os.date('*t')
if now.hour >= 8 and now.hour < 13 then
   grp.write('1/1/1', true)
elseif now.hour >= 13 and now.hour < 14 then
   grp.write('1/1/1', false)
For enable/disable script above from 1 bit use this: (sample is assuming event script script above is called 'timebasedevent')
if event.getvalue() == true then
  script.enable('timebasedevent')
  script.disable('timebasedevent')
(11.06.2018, 21:59)Erwin van der Zwart Wrote: Hi,
Try this:
now = os.date('*t')
Thank you .
Try this:
now = os.date('*t')
The first code. Can we do different things with a true value and a false value?
We can do whatever you like to do with script, but can you specify your question better?
(17.06.2018, 10:59)Erwin van der Zwart Wrote: Hi,
Sounds good.
Sends different values with a 1bit true/false
That is already in the sample i gave you (:
(18.06.2018, 09:54)Erwin van der Zwart Wrote: Hi,
Sorry my fault.
I want almost do the same.
I want just active the light, only between 5.30 am and 10 am.
my question is, is it also possible to do it with hours and minutes?
i m sure it is, but im just a beginner, who will convert my Gira Homeserver to the LM.
(05.04.2021, 10:03)Dré Wrote: I want almost do the same.
did you try the schedule?
I hope not to use the schedule this time, i want to use the script, for making it happened.
You can convert current time to a number of minutes passed since 0:00 and use it in your calculations. Use this example to check if current time is between 5:30 and 10:00
function tominutes(h, m)
  return h * 60 + m
now = os.date('*t')
mins = tominutes(now.hour, now.min)
if mins >= tominutes(5, 30) and mins <= tominutes(10, 0) then
  -- do something here
