Communicate HL and Telegram bot?
Hi, thanks to Domoticatorino and Edwin I have set up the homeLYnk to send messages to a Telegram Bot on event. That way the system can send messages on alarmas or events.
Now I'm thinking the next level, send some orders in Telegram to know the status of KNX addresses or even to set setpoints, on/off. Do you know how can it be done?
Thank for your help.
There is no listener for that in the device, a possible solution could be using IFTTT in combination with remote services.
There is a post on this forum (i posted it a more then a years ago) that would help you setting it up.
(20.07.2018, 06:53)legolas2069 Wrote: Hi, thanks to Domoticatorino and Edwin I have set up the homeLYnk to send messages to a Telegram Bot on event. That way the system can send messages on alarmas or events.
Hi! Can you explain how you set up the homeLYnk to send messages and alarms by Telegram?
See this: https://forum.logicmachine.net/showthrea...1#pid17111
(18.10.2021, 06:53)admin Wrote: See this: https://forum.logicmachine.net/showthrea...1#pid17111
Ok thanks!
I have problems with step 4. When I go to the web page that indicates, I get this. How can i fix it?
You didn't fallow instructions correctly, try again.
(18.10.2021, 07:39)Daniel Wrote: You didn't fallow instructions correctly, try again.
I create my bot with fatherbot, I type a message on my own bot but when I clic on the lynk https://api.telegram.org/bot<token>/getUpdates
[url=https://api.telegram.org/bot<token>/getUpdates][/url]I still get the same thing. What can I be doing wrong?
Replace <token> with your token
Then read point nr 3 again.
(18.10.2021, 08:06)Daniel Wrote: Then read point nr 3 again.
Ok thank you, i got it
