Datatypes knx
I was wondering if it was possible to either add datatypes or change. For example i want to show hvac 20.102 in Ets,comfort, standby. But there is only support for 05. 1 byte unsigned integer which shows 1,2,3,4..
Any ideas?
You can use custom values for that.
(26.07.2018, 23:18)Erwin van der Zwart Wrote: Hi,
Perfect, found it. But is it possible to make mass editions, or is it just one and one. Which makes alot of work.. To write this every time.
Thanks for reply Erwin..
on left side of object tab filter all needed GA (1/1/1,1/1/2,1/2/* etc.) then press Mass edit button on bottom of page, then select custom values
