Threads: 60
Ok, go to the scene tab and add new scene, give it name, now try to select a 4bit object as the trigger object. This is not possible. It would be useful to have this.
Thanks,
Roger
Threads: 31
Why 4bit? usually it is a 1byte object.
Threads: 60
because we program our light switches to an generic group address and use the LM to recall the scenes stored. That way is a lot more flexible and there is no need to reprogram the light switch when adjustments are required. changes are made to the scene on the lm.
we have basalte light switches, each sensor is configured a dim, that gives two objects, a switching object and a 4bit dimming object. then I would have 3 scenes per sensor for dimming. each scene triggers on their respective dimming value 9,0 and 1. if you get what I mean.
thx,
Roger
