Polling status
I´m scratching my head a bit concerning what to do if there is a fire alarm. Obviously, it´s fairly easy to turn off things that need to be turned off.
My concern regards lights. Is there a way, in a script, to poll every lights current status and save that state if the group address for the firearm goes true?
The scenario would be this:
Fire alarm goes off. Every appliance turns off and all lights go to 100%. 3 minutes after the fire alarm has been reset, the lights go back to the state they were in before the fire alarm went off.
I´m not even sure if this is what people do when it comes to KNX and fire alarms...
(02.12.2015, 22:45)FatMax Wrote: I´m scratching my head a bit concerning what to do if there is a fire alarm. Obviously, it´s fairly easy to turn off things that need to be turned off.
what we do:
- connect all devices to a scene
- when firealarm on: save scene - turn lights on / blinds up
- when firealarm off: call scene
what we do:
Thanks for the tip! Haven't worked too much with scenes yet. What you are saying is that you can save scenes on the fly with KNX, and not have to pre-program these in ETS?
what we do:
Yes thats possible, send 0..127 for calling scene 1..128 and send 128..255 to save scene 1..128. If you use scene 1 you can use to send 0 and 128.
Or you can make a script to save/recall values of all objects mapped to a certain tag. Map this script to a binary object, where ON saves tagged object values and OFF recalls saved values.
value = event.getvalue() -- save states if value then   objects = grp.tag('my_object_tag')   store = {}   for _, object in ipairs(objects) do     store[ object.address ] = object.data   end   storage.set('my_objects', store) -- restore states else   store = storage.get('my_objects', {})   for addr, value in pairs(store) do     grp.write(addr, value)   end end
Excellent inputs! Thank you so much guys :-)
(04.12.2015, 07:26)admin Wrote: Or you can make a script to save/recall values of all objects mapped to a certain tag. Map this script to a binary object, where ON saves tagged object values and OFF recalls saved values.
Sorry, Can you tell me more about the above code? I don't understand how to apply it yet.
Thanks!
This script is obsolete. Scenes should be used instead. Current values for a given scene can be saved from a script: https://openrb.com/docs/lua.htm#scene.savelive
(30.08.2023, 07:58)admin Wrote: This script is obsolete. Scenes should be used instead. Current values for a given scene can be saved from a script: https://openrb.com/docs/lua.htm#scene.savelive
Sorry, I don't know much about Lua. Can you give me an example?
Thank!
Create a scene named Test scene and add objects that you want to control with it.
Then create a 1-bit object an map event script to it. When writing ON (true) it will save current object values that are assigned to this scene. When writing OFF (false) it will run the scene.
value = event.getvalue() name = 'Test scene' if value then   scene.savelive(name) else   scene.run(name) end
(30.08.2023, 09:22)admin Wrote: Create a scene named Test scene and add objects that you want to control with it.
Yes, I will try following your instructions!
Thank!
