influxdb
I want to store LM object (values) data in an influxdb database, does anybody have any experience with this?
Their documentation (https://docs.influxdata.com/influxdb/v1....ting_data/) says that you can use the http api for storing data like this;
curl -i -XPOST 'http://localhost:8086/write?db=mydb' --data-binary 'cpu_load_short,host=server01,region=us-west value=0.64 1434055562000000000'
Is this possible from lua in the LM?
Thanks Mischa
http = require('socket.http')
http.TIMEOUT = 5
res, err = http.request('http://192.168.1.2:8086/write?db=mydb', 'cpu_load_short,host=server01,region=us-west value=0.64')
log(res, err)
http.TIMEOUT = 5
log(res, err)
Thanks, works perfectly.
I have tried this influxdb-connection and got it to work.
I want to write several tags to influxdb and can't really figure out the best way to do this in scripts.....
Data like temperatures, Co2 and also presence objects are data I need to log i influx.
Could anyone give me a push in the right direction here.
Planning to use this with grafana.
Everything is up and running but can't figure out the most vital part:-)
Eirik
This code will send everything it captures to influx, then you can filter whatever you want in grafana. Create resident script with zero delay
local http = require('socket.http')
http.TIMEOUT = 5
local dt_cache = {}
function get_value(addr, datahex)
  local dt = dt_cache[addr]
  if(not dt) then
    dt = grp.find(addr)
    dt_cache[addr] = dt
  return knxdatatype.decode(datahex, dt.datatype), dt
function knx_callback(event)
  local addr = event.dst
  local value, dt = get_value(addr, event.datahex)
  send_metric('rawdata', dt.name, addr, value)
function send_metric(table, name, addr, value)
  if(name == nil or name == '') then
    return
  name = string.gsub(name, ' ', '\\ ')
  local url = 'http://IP:8086/write?db=knxdb'
  local args
  if(type(value) == 'boolean') then
    args = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)
    -- most likely number
    args = string.format('%s,name=%s,addr=%s value=%s', table, name, addr, value)
  res, err = http.request(url, args)
  if(err ~= 204) then
    log('error sending to influx', res, err, args)
function run_loop()
  local bus = require('localbus').new(1)
  bus:sethandler('groupwrite', knx_callback)
  local busfd = socket.fdmaskset(bus:getfd(), 'r')
  while(true) do
    res, fbus = socket.selectfds(10, busfd)
    if(fbus) then
      bus:step()
run_loop()
