Threads: 57
Hi.
I find that 3G modems tend to be replaced by newer models as time goes by. Any tips for a compact and cost effective 3G modem for sending/reciving sms with LM5?
Kai-Roger
As an alternative you can try a separate modem with RS232 interface.
Threads: 57
03.09.2018, 10:48
(This post was last modified: 03.09.2018, 10:49 by Kai-Roger.)
Thanks. Do you know if this product have good quality and stability?
Is there a good RS232 modem to recommend altso, as an alternative?
Threads: 57
Cool. I will look into it. Thanks.
Threads: 103
Just a question. Wouldn't be VoIP client integrated in LM better solution?
Yes, there are many other solutions like paid web services for SMS or something like a bot for Telegram. Using a local modem has one advantage of not depending on Internet connection.
Threads: 57
Yes. In my case, i will have the sms sender as a security backup solution in buildings in parallel with communication over the internet.
Threads: 57
Is it possible to use a USB2.0 hub on the LM USB port, to connect both GSM and Z-Wave stick?
Yes probably necessary to use power injector.
Kai-Roger
Threads: 99
yes, you can do that. But please use external powering for the USB-hub.
Threads: 8
Is it LM5 Supports to 4G or 5G USB dongle for sending SMS?
