Threads: 3
Good afternoon.
I have a Schneider Spacelynk in an installation. It has 25 trendlogs working fine since a few weeks ago. Now 20 of then are empty and not registering anymore. Just five are working fine. I couldn't find any log nor error and really don't know how I can fix it, unless without erasind and loading again definitions. Maybe a sd card problem?
Thank you.
Threads: 30
SD card problem would stop all trends not just some. Can you create new trend and see what happen?
How much memory do you use? Which FW?
Threads: 161
Do objects still exists? Maybe you deleted objects?
Done is better than perfect
Threads: 3
Hi. I've just deleted one trend and created it again. It works flawlessly. All objects are ok. This problem happened weeks after end programming.
Actually I've just used 24% of total memory. Firmware is last version from Schneider: 2.3.0
Threads: 30
Can you send your project backup to PM? I will check it out.
Each trend log is stored as a separate file so if there was a power outage during automatic project sync then some trend files can be lost. If you don't have a recent backup then the only solution is to delete and create missing trends again.
