Read values in scheduled script store in ftp
#21
I cant get this script to work:
tagname = 'log'
logtime = os.time() - 60 * 60
query = [[
SELECT ol.*, o.name, o.datatype
FROM objectlog ol
JOIN objects o ON ol.address=o.id
JOIN objecttags t ON o.id=t.object
WHERE t.tag=? AND logtime>=?
ORDER BY id DESC
buffer = { 'date;name;value' }
items = db:getall(query, tagname, logtime)
for _, item in ipairs(items) do
  id = tonumber(item.address) or 0
  logdate = os.date('%Y-%m-%d', math.floor(item.logtime))
  etype = item.eventtype
  if (etype == 'write' or etype == 'response') and item.datatype then
    value = grp.decodevalue(item.datahex, item.datatype)
    if type(value) == 'number' then
      value = tostring(value):gsub('%.', ',')
    value = ''
  buffer[ #buffer + 1 ] = string.format('%s;%s;%s',
    logdate, item.name or '', tostring(value))
csv = table.concat(buffer, '\n')
I got nil.
I want to read meters convert to: buffer = { 'date;name;value' }
and send email once every sixth our.
Thanks for help.
The script itself works, did you tag the objects? Did you enable logging to them? Did you change logged objects value to have anything to show?
If you want to send periodical values you can use current object values instead of object logs. In this example all objects with the electricity tag are added to the CSV report.
objects = grp.tag('electricity')
for _, object in ipairs(objects) do
  logdate = os.date('%Y-%m-%d', math.floor(object.updatetime))
  value = object.value
    logdate, object.name or '', tostring(value))
log(csv)
Hi again.
I got the script to work.
Now the problem i don´t know how to use it.
please help me.
Hi.
I have solved the problem.
Thanks for the help.
