08.01.2019, 08:05
How is developing of the new version going? When it will be available via cloud?
Done is better than perfect
Mosaic 3.0 Beta - bug report
08.01.2019, 08:05
08.01.2019, 09:00
10.01.2019, 10:13
I think there is to small space for 3 digit number + one decimal and unit name with more than one letter. Example attached. Maybe adding some possibility to resize just the number and unit text could do the trick? BR Kai-Roger
10.01.2019, 10:37
(10.01.2019, 10:13)Kai-Roger Wrote: Hi Hi Which widget is this? In Widget creator you can set font size. BR
10.01.2019, 10:53
This is my another feedback:
1) In Widget Creator sometimes position changing to float number. It occures when something changed and after clicking Save button for current control. 2) Widget should have size excluding header, Normally Height == 1 is too small for anything because most of it occupies the header, but 3 is too big. And change from 1 -> 3 is not linear(from the point of available new space). Probably because of this the grid starts below header not on it. And also there should be a icons filter for icon searching.
06.03.2019, 07:43
And also please add some short tutorial how to reuse custom widget, e.g. how create widget and then in same room add its copy with another objects, bacause probably there is some little issue in this function.
I've found another issue:
1. In room "FRONT" there are 2 switchable lights. 2. I've added custom widget and after save it replace second light. This is the same if I've created new widget or import. THIS WAS SOME BUG IN VIEW MECHANISM. AFTER FULL REFRESHING ALL ADDED WIDGETS APPEARED.
(06.03.2019, 07:43)buuuudzik Wrote: And also please add some short tutorial how to reuse custom widget, e.g. how create widget and then in same room add its copy with another objects, bacause probably there is some little issue in this function. This is simple. In widget creator once widget is finished you just press add to custom widgets. Then you can go to a room you want to add it and it will be on widget list under custom. (06.03.2019, 08:56)buuuudzik Wrote: I've found another issue: I see everything correctly, maybe it was browser cache or similar. (06.03.2019, 06:21)buuuudzik Wrote: This is my another feedback: The floating bug recreated, thanks The 2 other points will keep for future evolution.
06.03.2019, 09:47
Yes, there is some bug with apropriately refreshing view after adding new widget. After full refresh all looks like it should.
06.03.2019, 12:17
And nice would be if there would be a possibility to hide all not necessary links to rooms. But only on this screen and going to them should be possible via trees Floors, Rooms, Systems.
06.03.2019, 12:21
(06.03.2019, 12:17)buuuudzik Wrote: And nice would be if there would be a possibility to hide all not necessary links to rooms. But only on this screen and going to them should be possible via trees Floors, Rooms, Systems. Not sure what you mean. There is option to hide room from user. Next to room name there is eye icon, once selected this room will be visible only for admin.
06.03.2019, 12:36
(06.03.2019, 12:21)Daniel. Wrote:(06.03.2019, 12:17)buuuudzik Wrote: And nice would be if there would be a possibility to hide all not necessary links to rooms. But only on this screen and going to them should be possible via trees Floors, Rooms, Systems. Yes, I've noticed this and it is some solution but I mean more visual optimization, nothing with authorization. I think that when there is a tree there is no need(or could be chosed) if some or all room links should be showed on the Main screen. This especially is a big deal on a smartphone where screen is not so big as on PC or tablet.
06.03.2019, 12:42
(06.03.2019, 12:36)buuuudzik Wrote:Sorry but I still don't know which links you mean. There is only navigation menau (Tree) and on top option to filter via function. Can you drop some screenshots?(06.03.2019, 12:21)Daniel. Wrote:(06.03.2019, 12:17)buuuudzik Wrote: And nice would be if there would be a possibility to hide all not necessary links to rooms. But only on this screen and going to them should be possible via trees Floors, Rooms, Systems.
06.03.2019, 13:50
Screenshot attached. I like this links but it should be configurable which should be visible because to much of them occupies a lot of place.
06.03.2019, 14:20
This is homepage only and you can switch it off in settings. Do you say that you want to be able to choose which rooms are visible on home page?
(06.03.2019, 14:20)Daniel. Wrote: This is homepage only and you can switch it off in settings. Do you say that you want to be able to choose which rooms are visible on home page? Yes, this is what I've mean ![]() ![]() Thanks
07.03.2019, 06:00
Is there a possibility in Mosaic to create links to rooms? Then I can switch off them but create links only for specific rooms.
07.03.2019, 09:44
Hm not out of the box. There is HTML widget where you should be able to do it.
