New ekey packages for ekey FSX scanners
Hi, here are the links to download the new ekey packages for ekey module (FSX) scanners:
LM5:
http://www.ekey.lv/logicmachine/luaekey_20180801_imx6.ipk
http://www.ekey.lv/logicmachine/genohm-scada-ekey_20190121_imx6.ipk
LM3, LM4:
http://www.ekey.lv/logicmachine/luaekey_20180801_mxs.ipk
http://www.ekey.lv/logicmachine/genohm-scada-ekey_20190121_mxs.ipk
The app remains the same, but there are many back-end improvements on stability and functionality.
New functions:
1.       User can select the required RS485 port for communication to ekey scanners. As RS485 port can also be used ekey USB converter
2.       Implemented database for the ekey user credentials (fingerprints, RFID cards)
3.       Commands to transfer ekey user credentials (fingerprints, RFID cards) from fingerscanners to database or reverse
4.       Fingerprint/RFID card enrollment, delete with following sync to all active scanners and database
5.       Enabled the scanner ‘multiple enrollment” mode
6.       Enrollment of new fingerprint with following sync to all active scanners and database
7.       Enabled scanner “self-learning” function with following sync to all active scanners and database
8.       Supported the scanner with REL functionality (can switch ekey on-board relay)
9.       Supported the scanner LED lamp controls
10.    Scanners must be activated using access code based on its serial number
11.    System is tested with 10 scanners simultaneously connected to the single RS485 port.
12.    The last full list of the known FSX type scanners are listed bellow:
     code ="801566", description="ekey FSX IN 2.0"
     code ="801582", description="ekey FSX AP 2.0"
     code ="802010", description="ekey FSX UP E"
     code ="802011", description="ekey FSX UP E REL E"
     code ="802012", description="ekey FSX UP E RFID E"
     code ="802013", description="ekey FSX UP E RFID REL E"
     code ="802015", description="ekey FSX UP I"
     code ="802017", description="ekey FSX AP 2.1 REL"
     code ="802018", description="ekey FSX AP 2.1 RFID REL"
     code ="802082", description="ekey FSX IN 2.1"
     code ="802084", description="ekey FSX IN 2.1 RFID"
     code ="802102", description="ekey FSX AP 2.1 RFID"
     code ="802291", description="ekey FSX UP RFID I"
     code ="802670", description="ekey FSX UP RFID REL"
     code ="802671", description="ekey FSX UP I REL"
     code ="802827", description="ekey FSX UP E SC"
     code ="802828", description="ekey FSX UP RFID E SC"
     code ="802836", description="ekey FSX UP I SC"
     code ="802838", description="ekey FSX UP RFID I SC"
·         the “ekey home” or “ekey net” scanners are incompatible with this application.
Hi, unfortunately links are not working anymore. How can this version be downloaded?
