Simple Script "less than" help
Hi.
There is something wrong with "OUTPUT = false" at the end of the script. I can't find out what i should write instead.
Kai-Roger Kolseth
INPUT-A= grp.getvalue('63/1/1')
INPUT-B = grp.getvalue('6/2/11')
OUTPUT = grp.write('1/0/108')
if INPUT-A < INPUT-B  then OUTPUT = false
Variable names cannot have minus signs in them, because it's a math operator.
INPUT_A = grp.getvalue('63/1/1')
INPUT_B = grp.getvalue('6/2/11')
if INPUT_A < INPUT_B then
  grp.write('1/0/108', false)
(31.10.2018, 13:40)admin Wrote: Variable names cannot have minus signs in them, because it's a math operator.
Sorry. I wrote it wrong in the tread. Should have been INPUT_A and INPUT_B as it is in my script.
The way you write it is working fine, but i want to have the output as a variable. Is that not possible in LUA?
Can be done like this:
OUTPUT = grp.find('1/0/108')
OUTPUT:write(false)
Absolutely brilliant  Big Grin Thanks
