Threads: 9
When you have an icon / shortcut on your tablet or mobile phone, I usually add "desktop to desktop" in browser. Is there anyone able to change the icon that comes on the desktop? Is there a way in LM5 lite to enter the desired icon?
Threads: 9
Thank you, I have uploaded two files via FTP, but where should the script be? event-resident-user libaries-commond functions or start-up?
Is there any requirement that the size of the picture
Threads: 31
You just need to run it once so it can be event or resident but make sure you disable it after one run, you can add a log to see if it went trough.
Threads: 9
13.11.2018, 09:50
(This post was last modified: 13.11.2018, 09:53 by oyvindnordbo.)
Unfortunately, I do not get this to work, have now created a resident script, set the interval to 30sec, pasted the script I received, enabled the script and immediately disabled it. When I see in the "show logs window" there are no error messages.
I'm now trying on a spacelynk because I had no access to the LM now
Threads: 31
Add this on the end of script
log('script did run once')
-- Disable script when done automaticly
script.disable(_SCRIPTNAME)
You will see such log in logs and script will disable itself so you just have to enable it.
Threads: 9
I've managed to change the others like it's barked over, bu is it avble to change the icon to Mosaic/Touch favicon?
You need to use ftp login/username, not apps. Upload files directly to the root directory.
You need to upload visualization.png and touch.png to the root directory of FTP (the one that is empty right now). Then run the script from the previous post.
