Threads: 9
When you have an icon / shortcut on your tablet or mobile phone, I usually add "desktop to desktop" in browser. Is there anyone able to change the icon that comes on the desktop? Is there a way in LM5 lite to enter the desired icon?
Threads: 9
Thank you, I have uploaded two files via FTP, but where should the script be? event-resident-user libaries-commond functions or start-up?
Is there any requirement that the size of the picture
Threads: 21
You just need to run it once so it can be event or resident but make sure you disable it after one run, you can add a log to see if it went trough.
Threads: 9
13.11.2018, 09:50
(This post was last modified: 13.11.2018, 09:53 by oyvindnordbo.)
Unfortunately, I do not get this to work, have now created a resident script, set the interval to 30sec, pasted the script I received, enabled the script and immediately disabled it. When I see in the "show logs window" there are no error messages.
I'm now trying on a spacelynk because I had no access to the LM now
Threads: 21
Add this on the end of script
log('script did run once')
-- Disable script when done automaticly
script.disable(_SCRIPTNAME)
You will see such log in logs and script will disable itself so you just have to enable it.
Threads: 9
I've managed to change the others like it's barked over, bu is it avble to change the icon to Mosaic/Touch favicon?
