Custom Css Circularslider
Hi everyone,
When i use a circular slider to control, for example, the temperature of a room, the size of the number in the middle of the circle is too small.
I'm not sure if i could change it using a custom CSS and what kind of class i have to use.
I would appreciate any help.
Try this
.circularslider-value {  font-size: 40px !important; }
(13.11.2018, 16:48)Daniel. Wrote: Hi
Try this
Thanks Daniel. It's works. As I saw that there is a limit from which the text is cut; can not this limit be removed?
It is just another element which is overlapping it. Not sure if this can be changed.
Try this
Hi, you can add "padding" to remove text cut
I have another question:
I want change circular slider color dinamicaly (deppending of the valve) but I don´t find css class. I´ve seen that circular slider control is a canvas.
How can I change the color?
You can change color via hue-rotate CSS filter. In this example additional class is set to slider and control object is 32/1/2. This will only work in "show control" mode.
$(function(){   if (typeof grp === 'object') {     grp.listen('32/1/2', function(obj) {       $('.slider').css('filter', 'hue-rotate(' + (obj.value * 3) + 'deg)');     });   } });
