Threads: 1
Guys i need help ...i never work with FB before
i setup an gr.adrs with 16 binary inputs and i want to use a function to change one output adr. for an actuator regardless of which binary input it's active.
can you help me please?
Threads: 35
Please explain it better, are you talking about an or gate with 16 inputs?
Threads: 35
So you have 16 Boolean group addresses and when any of them is ON/true you want to send ON/true to another group?
Threads: 1
That's exactly what I mean.
Threads: 35
(28.11.2018, 18:14)MAdbUSU Wrote: That's exactly what I mean.
Then this is 16 input or gate
you can use this script
https://forum.logicmachine.net/showthrea...18#pid1518 but if you really want to use FB then I can make you new block for it tomorrow.
Threads: 35
Where from did you took this block?
Threads: 35
Yes you can, last telegram wins, so it is better to make output of first OR to input to next OR. But again where did you found this earlier block with TAG?
Import this block under scripts->user libraries
https://we.tl/b-5RFmzi76b4
I was trying to make it universal with tag but they seems to not working in FB.
Threads: 1
29.11.2018, 10:21
(This post was last modified: 29.11.2018, 10:23 by MAdbUSU.)
Now I'm out of office, but I will make a screenshot of it.
(It's from an OR function menu not an OR GATE)
I did make something before I leave the office with 3 OR GATE, it's works but I have micro interruption on output when I switch some inputs on second OR GATE , I'M not sure if it's ok like that.
Threads: 1
it's not working ...from the 9 input the gate it doesn't give any output...any clue?
Threads: 35
(29.11.2018, 11:31)MAdbUSU Wrote: it's not working ...from the 9 input the gate it doesn't give any output...any clue?
yes sorry use this
https://we.tl/t-zgtUDuepcQ
Threads: 35
Where from did you get this library? it is not part of the app by default. You can export this library in the same place you imported my. Send it and I will check if it can work. I didn't manage to make tag to work.
