Use Booleon to send 3 values
I would like to use a booleon to send three values. I am mostly using the FBEditor to create logic. But i cant seem to find the right way to get this solution to work.
Is there some converter of some kind?
Hi.
You can use this script to send three values.
Copy and paste in an event based script.
value = event.getvalue() if (value == true) then -- true or false   grp.write('1/1/1', true) -- change group adress and value   grp.write('1/1/2', 50)   grp.write('1/1/3', 100)   grp.write('1/1/4', 255) else   grp.write('1/1/1', false)   grp.write('1/1/2', 0)   grp.write('1/1/3', 0)   grp.write('1/1/4', 0) end
