Threads: 30
Hi!
I now have the strange problem of the last device in the bus not getting messages. Do I have to do something to be able to do that?
Threads: 86
30.12.2018, 12:50
(This post was last modified: 30.12.2018, 12:51 by AlexLV.)
Hi!
Easy way to check - take tester or DC voltmeter. Voltage on standart DALI line shoud be 18V DC (Standart Dali Power supply) . Works fine up 15V DC. If less - can be problems.. Some OSRAM DALI devices give more than 18V voltage to BUS. May be depend from signalling on DALI bus, we just measure DC part of voltage..
Please take attention to some Touch-Dim DALI ballasts, with them you can Swich On/Off or dim your light connecting phase (230V AC) to DALI input. !!!!!!!! NOT COMPATIBLE to standard DALI ballasts, they will be killed connecting such way..
BR, Happy New Year,
Alex
Does it react to broadcast commands sent from scripts?
Threads: 86
I plan to buy some Lunatone dimmers, can you please write model you use??
Alex
