Scenes are applying after reading
Scenes are applying after every reading. Is it a bug? I want apply my scene after writing only Can change this behavior?
Thank you
Sorry, my mistake. Not the reading requests but the following responses are re-applying scenes. Can I disable it?
This is the same as with scripts that react to both group write and response the same way. It's not possible to disable this behaviour, but you can attach your scene to another object and write a small script that passes value to it only in case of group write.
if event.type == 'groupwrite' then
  grp.update('32/1/1', event.getvalue())
