Threads: 1
18.01.2019, 13:49
(This post was last modified: 18.01.2019, 13:58 by Bar4tus.)
Hi, I need to create a column chart with weekly electricity consumption and water consumption.
I need to connect KNX objects with data from Monday to Sunday and show them on the bar graph,
I need to use Google api or something like that?
I'm just starting with js and css, so I need help
Threads: 31
Month view shows days consumption,
You have probably selected absolute value mode instead of counter.
Yes, absolute value is meant for temperature sensors and similar data. In your case counter mode should be used.
Threads: 31
Weekly view shows data in the same resolution as daily. Monthly view will show you daily consumption.
Threads: 10
The raw data is stored in the history trend, the history service make this data available. Grab data, send to Google and then chart it?
