Pop-Up Window
HI!
I need create a window pop-up when the bit object change their state in the same page of visualitzation.
If the state is 1, the pop-up window show a one notification (ex: NOTIFICATION1) and if the state is 0 the pop-up window show an other notification (ex: NOTIFICATION2)
The notifications it's like image.
[Image: X16CV.png]
You can Alerts for that. First, you need to enable "Show alerts in Usermode" in Utilities > Vis. configuration. Then create a script attached to the required object:
value = event.getvalue()
if value then
  alert('value is 1')
  alert('value is 0')
